Go Back   The British Construction Equipment Forum > EXTRAS > Models
  #1   IP: 124.168.222.248
Old 20-09-2012, 02:30 PM
scraperad scraperad is offline
Default Old Cat D4 and Cat 40
Have now finished my latest addition to the fleet.
All scratch built from plastic and brass tube etc except for the aircraft wheels
Alan
  #2   IP: 109.150.44.124
Old 20-09-2012, 07:14 PM
Guest1 Guest1 is offline
Default Re: Old Cat D4 and Cat 40
Is this the Alan I think it mighnt be
  #3   IP: 195.93.21.33
Old 20-09-2012, 08:50 PM
Alan you have been a member here for a very long time and this is your first post ...... Absolutely excellent !!
  #4   IP: 81.151.38.203
Old 20-09-2012, 09:12 PM
You sir have patience of a saint.. Im certain that i would smash those up within minutes from sheer frustration
  #5   IP: 124.168.222.248
Old 20-09-2012, 11:18 PM
Thanks for the comments.
Lord-Sean I dont thinks so.
Im originally from NZ now in Melbourne
Alan
  #6   IP: 109.150.44.124
Old 20-09-2012, 11:43 PM
Alan
I have a good mate of the same age who makes models from scratch called Alan....he uses brass tube,plastic,bits of old tv aerials,and usually robbs wheels for his models from other die cast models as the wheels are the one thing he can't produce himself.
  #7   IP: 124.168.222.248
Old 21-09-2012, 01:43 AM
Yes I have the same problems. Wheels and tracks are the biggest problem. I am not happy with the tracks here which I have made from plastic tubing and sheet. A lot of time and patience, 64 links each made from 8 pieces. Also the sprockets, rollers and front idlers are a pain to make. At least now I am retired I have time to waste doing it.
I have been making models of all the older equipment I have driven. Next on the plan is a CAT D6B which I have started.
  #8   IP: 81.155.253.148
Old 21-09-2012, 02:38 AM
ontick ontick is offline
Thats a cracking model.
  #9   IP: 2.102.40.161
Old 21-09-2012, 08:08 PM
Very detailed brilliant I've got a model of a unimog (a bought kit) put the doors on the cab and then got fed up with it that's 8 years ago now still in the shed waiting to get finished (well started)
very short attention span
Paul.
  #10   IP: 86.169.189.206
Old 30-09-2012, 05:52 PM
That is very impressive. You have a lot more patience than me and a darn sight better eye for detail thats for sure.
