  #11   IP: 2.13.126.128
Old 12-03-2016, 10:38 PM
Default Re: Dumper nudgeblade
Originally Posted by diggerman View Post
that is simply brilliant.ive often thought about it but never done nothing about it.im amazed farmers with stock don't buy dumpers and remove the skips and put three point linkage on the front and have scrapers for pushing slurry about.i certainly would if I still kept 2500 pigs
nick...........
I sold a 1 ton dumper to a farmer and he did just that - said it was the biz - I never saw the finished article though.
  #12   IP: 86.139.39.242
Old 15-03-2016, 01:16 AM
https://youtu.be/ASNxDMl-DcE
Interesting unit
  #13   IP: 217.44.142.92
Old 15-03-2016, 06:52 AM
Yes I'm sure this type of attachment has been done here before. Didn't Mog do some interesting things to dumpers?
  #14   IP: 86.132.146.192
Old 15-03-2016, 07:04 AM
Mog does interesting things to a lot of stuff
  #15   IP: 81.147.152.163
Old 11-10-2016, 08:59 PM
Originally Posted by AtlasRob View Post
It's been somewhere before as I definetly remember seeing it. That said I get email updates from that site and may have seen it there.
If the manufacturers let the skip tip a little further or altered the front of the skip slightly you would be able to doze with the skip like I remember doing years ago .
Just looking at this thread again ....... for some reason?
The Humper-Dumper's skip actually touches the ground on full tip and dozes a treat .... IIRC she's a very early frame steer Thwaites 2.5 tonner ... big ol' skip on her.
Stick a block under the front of the skip and the wheels are off the ground in a second .... if you get a puncture !
Down side of it is the hand crank Petter twin ..... anticlockwise!!! ..... just weird!!!!!! (for a right hand-er anyway ... might be easier if yer's a left hooker?)
  #16   IP: 109.157.255.173
Old 11-10-2016, 09:13 PM
I have a lister driven pump that's an anti-clockwise cranker. It didn't have a handle when I acquired it, so l made one........ A clockwise one............that didn't go well.
  #17   IP: 81.147.152.163
Old 11-10-2016, 11:24 PM
sat here rocking with laughter Chris !! The boss shouts down "Keep the laughter down"!
I had to make one for this 'un too ..... fortunately the end of the crank has a ramped sprag dog for a cross pin handle .. otherwise I'd have probably done the same .... anti-clocks aren't exactly abundant
  #18   IP: 92.40.248.96
Old 12-10-2016, 09:33 PM
delbouy delbouy is offline
The starter handle I got for the Winget and the mixer is a Lister handle, and they both have a pin in them on a spring, the pin can be turned around the do Clock and Anti-clockwise wise,
They are bloody heavy tho, on there own, all cast.
  #19   IP: 81.147.152.163
Old 12-10-2016, 11:00 PM
one like these Del?
they are bloody heavy and would not want it smacking you in the face
  #20   IP: 86.169.179.21
Old 12-10-2016, 11:08 PM
got a big dent in top of my nose from one of them
