  #41   IP: 95.147.72.30
Old 27-11-2016, 11:17 AM
Cheggars Cheggars is offline
Default Re: Device for assisting in hose coupling?
Would something like a Stanley trigger clamp be strong enough?
  #42   IP: 86.182.78.212
Old 27-11-2016, 12:15 PM
Do away with the problem altogether and use screw on like Atlas & Hydrema quite why Druid removed his I'm still not 100 sure
I am really flat face are easier to source when you first start looking and it can be an easy enough decision.
Whether that is true later on and experience shows it would be better to stay with screw on I cannot confirm or deny.
  #43   IP: 81.158.240.165
Old 27-11-2016, 03:16 PM
Pedrod316 Pedrod316 is offline
I cant see it been any where near strong enough and as druid said you would need arms like popeye to press it in!
Car jack idea would be best option or a spring claml maybe?
The quick on clamp works on a cantilever idea to get the pressure needed
If your changing fittings a fair bit the tool is worth it's cost,seconds each fitting job done, end of story...
  #44   IP: 31.49.234.24
Old 27-11-2016, 03:18 PM
Hydroscand Keep screw on's in stock locally
" "It's not just for money alone that one spends a lifetime building up a business…. It's to preserve a way of life that one knew and loved. No, I can't see my way to selling out to the new vested interests, Mr. Jorkin. I'll have to be loyal to the old ways and die out with them if needs must" - Mr Fezziewig, 1721 - Fuck knows dickens never told me.
  #45   IP: 31.185.213.2
Old 27-11-2016, 04:46 PM
I tried screw on, but once you get a bit of sand on them you can't get them clean. At least with flat face you can wipe them clean each time.
I'm sure when I bought my easy on it was about £80, so someone is making a huge markup now.
  #46   IP: 86.139.114.76
Old 28-11-2016, 08:04 PM
Originally Posted by AtlasRob View Post
Do away with the problem altogether and use screw on like Atlas & Hydrema quite why Druid removed his I'm still not 100 %sure
well I can confirm that ............... I won't be refitting the screw type Rob ... PITA cleaning up after 'em and keeping them clean.
The FFs can be an occasional PITA but no mess and easy to keep clean.
Plus they're a damned sight quicker and no bruised knuckles.
Still got the BIG screw ons, on her, on the change-over from the crowd, but they get used so infrequently, I'll live with them ...... for now, anyway.
  #47   IP: 2.27.223.121
Old 28-11-2016, 08:56 PM
Tidy enough solution.
http://en.stehr.com/stehr%20special%...aulic%20clutch
