  #1   IP: 86.164.76.147
Old 15-03-2012, 07:47 PM
Pecall's Avatar
Pecall Pecall is offline
Default CPCS theory answers
Thanks to kevthedig, I've got the answers for the theory test on 360s but I'm after the answers for 180s and forward dumpers now. If anyone has them and are prepared to give them to me I'd be most grateful. a lot of the questions are the same across the categories but there are a few item specific. I probably know the answers but they'd be in my own words and it appears that some examiners are a bit picky and want it word for word.
Thanks people.
DIPLOMACY; The art of telling someone to go to HELL, in such a way, they actually enjoy the journey
  #2   IP: 86.164.76.147
Old 15-03-2012, 10:27 PM
Pecall's Avatar
Default Re: CPCS theory answers
I'm Ahem Quite sure I have 180 answers here buddy. I'll try and dig them out this weekend.
You're a diamond geezer
  #3   IP: 86.166.42.254
Old 17-03-2012, 11:45 PM
Pecall's Avatar
Can't find them in my files... I shall ring a contact monday and see if he can help.
Retract my last statement Cheers Rory, most of the answers are the same as the 360 but there is 1 or 2.
  #4   IP: 95.144.192.116
Old 18-03-2012, 11:57 AM
theres one or two from recalection, One about checking the ground below your stabilisers and another about why if you had say a 1t load at full extension in line with your 3cx then slewed it to the side the machine would tip over. that one you do have to word just right.
Beware aswell when you come to picking up and slewing a load. We did ours on a NH110LB which is not really the best machine for it. it was feeling heavy at 90' whereas on a 3cx it would of been fine.
  #5   IP: 86.166.42.254
Old 18-03-2012, 12:04 PM
Pecall's Avatar
I'll have a proper look through them today. If there is any other answers I'm not too sure of, I'll ask. If that's ok of course
  #6   IP: 86.166.42.254
Old 20-03-2012, 01:07 PM
Pecall's Avatar
Do you have the study notes for the 180 Rory? They sent these for the 360 and dumper but not the 180. Most of the questions are the same and some are simple but there is a couple I'm not too sure of. I'm not overly worried as i reckon I've enough to pass.
  #7   IP: 80.229.166.233
Old 13-01-2014, 06:15 PM
the very hungry caterpillar's Avatar
the very hungry caterpillar the very hungry caterpillar is offline
Soverign Grand Inspector General
Exclamation Re: CPCS theory answers
PLease do not post copyrighted material. We have recently got into some hot water over this...
UK Distributors and Installers of: Lincoln Auto Lube Systems | Loadrite Weighing Systems | Alphaview Vehicle CCTV
  #8   IP: 92.40.113.208
Old 13-01-2014, 08:50 PM
That's a shame, Although it shows someone from CPCS is obviously watching.....
Perhaps they could show there face.... and tell me why despite doing all my tickets at college, an NVQ 2 in Plant and working really really hard all the goalposts are moving and I need another bloody category to lift things with a digger.....?
I would also like to do a NVQ3 in Plant.... could you explain why I can't?
Your's lovingly, - RJS
  #9   IP: 89.241.150.64
Old 20-01-2014, 10:53 AM
Pecall's Avatar
Can you really see them coming on here and telling the truth. They only brought in the NVQ to make the CPCS look professional. This lifting thing is a complete arse ache. They haven't implemented one thing to help operators.
  #10   IP: 31.48.79.220
Old 24-08-2014, 02:11 PM
I only just saw this while working out the best place to post about the lifting with excavators test.
The paperwork I was going to post is the Theory Test Questions but I've just twigged its got a copyright logo in bottom left and I don't want to start world war 3 with the CITB
Basically there are 26 questions, some of which have a two or three part answer.
All experienced operators will have a very good knowledge and be able to answer
them. The biggest problem is how to explain it on paper
