  #1   IP: 74.14.36.166
Old 03-01-2015, 01:32 PM
Hookedondiesel Hookedondiesel is offline
Default Tips and Tricks
Just thought I'd start a thread on things that we have learned over the years.
here's one for all the folks here,,
" if you hold the "SHIFT" key on your keyboard and click on a photo that someone has posted, it will open in a new separate window.
1994 JCB 210S 4x4x4
  #2   IP: 81.154.191.95
Old 03-01-2015, 03:48 PM
Default Re: Tips and Tricks
Right click on pic and select open new tab - piccy opens in new tab
  #3   IP: 74.14.36.166
Old 03-01-2015, 04:56 PM
Default Grease Gun
Did you know, your grease gun is adjustable....
Been working on mechanics for quite some time now and never knew this.
If the end of the grease gun keeps falling off the nipple,
you can turn the end to adjust it to fit tighter.
1994 JCB 210S 4x4x4
  #4   IP: 81.154.191.95
Old 03-01-2015, 05:03 PM
Default Re: Grease Gun
As Atlas'd say, "everyday's a school day" here.
I don't mind admitting I never knew that and I too have pumped too many guns to wish to remember, how many.
I shall be examining my guns the next time I have 'em in my 'graspers'.
Got a couple of nipples that are absolute bar stewards to keep the gun on (to the point I was going to change the nipples!!)
Ta muchly for that little gem!!
  #5   IP: 80.43.89.196
Old 03-01-2015, 05:07 PM
How about this then in a tubeless tyre with a slow puncture or leaking around the rim mix a bit of PVA wood glue with water and put some in the tyre
It remains liquid till it finds the hole then seals any holes up
We use an old fire extinguisher the type with the old screw top
with a air valve fitted to the top filled with PVA mix and a pipe going the the tyre valve
so can put the glue in the tyre then continue to inflate
Had a lot of success on the old volvo dump trucks we have
  #6   IP: 80.43.89.196
Old 03-01-2015, 05:11 PM
[QUOTE=Hookedondiesel;113722]Just thought I'd start a thread on things that we have learned over the years.
This would be a good thread to be STICKY and kept to the top of a page
  #7   IP: 74.14.36.166
Old 03-01-2015, 05:12 PM
MogMan, what is "PVA"?
1994 JCB 210S 4x4x4
  #8   IP: 80.43.89.196
Old 03-01-2015, 05:18 PM
Its that white wood glue................you know the type,
used to have it at school you'd paint it on you fingers let it dry then peel it off in the next class
  #9   IP: 94.197.120.249
Old 03-01-2015, 06:25 PM
delbouy delbouy is offline
A lot of people call PVA unibond these days,
And I used to do that a lot when I was younger, that's a good trick to get ground in oil and dirt out the grains in your hands, if you work it in well and put a nice thick layer on, it takes all the dirt away with it.
  #10   IP: 94.197.120.249
Old 03-01-2015, 06:29 PM
Another one is if you got a stubborn nut/bolt put the ring end of a combo spanner on the nut/bolt and hook the ring end off another spanner over the end of the 1st spanner, give you a lot more leverage.
I been doing this for years, and a mechanic friend of mine said, ( well I've never seen that done like that before).
He does it all the time now.
