  #1   IP: 81.158.88.120
Old 23-12-2015, 09:29 PM
Default Removing Stickers.....
Thought I'd share my latest Innovation.... been removing some stickers from my lorry today... Always have an issue removing the sticky residue.
Steal some Cif from the kitchen and coat where the sticker was... leave for a minute or so and partly dry it with a heat gun. Then Buff it out.
Works surprisingly well!
  #2   IP: 86.7.227.236
Old 23-12-2015, 09:57 PM
Default Re: Removing Stickers.....
I'll give that a try next time always done it with boiling hot water
  #3   IP: 86.174.116.60
Old 23-12-2015, 09:58 PM
Always used heat gun from the start and they peel off lovely without leaving a mess
  #4   IP: 82.132.239.83
Old 23-12-2015, 10:46 PM
+1 for a heat gun, then petrol to get any glue left on
  #5   IP: 213.123.178.61
Old 27-06-2016, 06:06 PM
baldgadge baldgadge is offline
Hi, go to your local paint shop and supply factors, many do a pad that goes in an elecric drill , thet are brilliant, saves hours, onlt thing is they wear quickly so get 2 ?,
regards bg.
  #6   IP: 5.254.163.144
Old 27-06-2016, 06:22 PM
regards bg.
That'll take the paint with it!
Petrol is better than any degreaser for removing the sticky residue.
  #7   IP: 86.132.146.175
Old 27-06-2016, 06:33 PM
It's a really soft rubber wheel Doob, I've used them in the past to remove decals from car paintwork, with no damage to the paint, if you keep an eye on temperature, they work well when needed, but as said, wear very quickly and wouldn't be cost effective for large areas on plant, trucks ect
Petrol or brake cleaner work OK to remove the adhesive , doling water will actually get some stickers off
  #8   IP: 5.254.163.144
Old 27-06-2016, 06:51 PM
Ah, I thought he meant the old scourer pad jobby!
Petrol will shift glues that brake cleaner won't in my experience.
  #9   IP: 80.247.25.141
Old 27-06-2016, 06:54 PM
pettsy pettsy is offline
I know them as toffee wheels
  #10   IP: 86.130.21.222
Old 27-06-2016, 07:44 PM
wd40 meant to be good for removing glue
