Go Back   The British Construction Equipment Forum > EXTRAS > PRODUCTS AND SERVICES
  #1   IP: 86.147.147.209
Old 23-01-2016, 06:54 PM
Farmer D Farmer D is offline
Default Lowloader
We now have an artic low loader on the road. Going all round the country, so if you need something moved please give us a chance.
lfpearce@btconnect.com or ring Derek 07980 602475 01844 238887
  #2   IP: 80.43.175.240
Old 23-01-2016, 07:54 PM
Default Re: Lowloader
What truck and trailer are you running
What weight can you carry
Where are you based
  #3   IP: 86.147.147.209
Old 24-01-2016, 08:40 AM
Volvo unit and andover trailer. So we can get 27 tonne on. The unit also goes off and does bulk too.
Based between Aylesbury and Oxford but travel all over. Up to Norwich on Monday and need a backload for him.................
  #4   IP: 86.135.103.134
Old 24-01-2016, 09:03 AM
Have you got your details at Cheffins Ely
Might be worth a call to Chris Day from Hungerford too
  #5   IP: 213.205.194.37
Old 24-01-2016, 09:21 AM
Is trailer proper low loader or step frame ?
  #6   IP: 86.147.147.209
Old 24-01-2016, 09:46 AM
Proper low load, ramps on back. Not a swan neck detachable one. Have sent cheffins some flyers will look at Chris day too. Many thanks.
  #7   IP: 213.205.194.37
Old 24-01-2016, 10:26 AM
So we could track dozers over the side. That's handy.
  #8   IP: 213.205.194.37
Old 24-01-2016, 10:29 AM
Just re read your post. You have step frame not low loader. We use low loaders a lot as we have heavy machines that often have to go over the side. Still use step frames though. Will you be getting permits for over width loads ?
  #9   IP: 82.132.231.186
Old 24-01-2016, 01:17 PM
ontick ontick is offline
Do you prefer to run them on side Tim I prefer over side but more people getting trailers with ramps
  #10   IP: 92.30.40.224
Old 24-01-2016, 01:38 PM
We have sites where we would have to track our machines on to the road in order to use ramps, 40 tonne excavators and D6's tend to make mess and cause damage one way or another, so over the side is much prefered. Always put the 40 toners and above on low loaders not step frames.
