  #1   IP: 86.131.146.133
Old 27-01-2016, 08:34 PM
Tinnerstoy Tinnerstoy is offline
Default service and parts manuals
Hi all, Just thought id share with you what I believe a good source of the above. Was a bit sceptic at first but they delivered good.
Put and end to days of searching for me.
http://sudoremont.com.ua
  #2   IP: 92.40.249.38
Old 14-02-2016, 09:47 PM
delbouy delbouy is offline
Default Re: service and parts manuals
Hello.
Great link, they seem to have a vast list of manuals,
How do I tel which one I need,
I'm after the manual for my 801'
How do I know what model my machine is?.
  #3   IP: 92.1.164.93
Old 14-02-2016, 10:24 PM
Originally Posted by delbouy View Post
Hello.
How do I tell which one I need,
You already said you have an 801 !!
Chassis number stamped on front behind king post.
  #4   IP: 31.49.234.28
Old 14-02-2016, 10:55 PM
His issue is his is a very early example Tim, Has a different undercarriage to most.
  #5   IP: 92.1.164.93
Old 14-02-2016, 11:07 PM
Rory he said it's an 801, so he knows the model. It has a serial number, a call to a dealer should help surely ?. You don't need a book for running gear he can measure components if any are needed.
  #6   IP: 217.37.82.34
Old 29-02-2016, 03:12 PM
steviemax steviemax is offline
Hello.
http://www.plantkeyshop.co.uk/epages...e%20Manuals%22
  #7   IP: 83.136.43.208
Old 06-04-2017, 02:57 PM
##dan## ##dan## is offline
Hi
I have tried links above.
Can anyone help with a manual for a 99 benford pt6000?
