  #1   IP: 92.135.183.229
Old 19-06-2017, 05:01 PM
Default Drainage Channels
I have some drawings showing 120m2 of tarmac with 1.5% fall to 3lm of 120MM wide channels connected to a 100mm pipe run of 40LM with .75% fall into culvert.
Will this be sufficient drainage ?
Client doesn't want wider channels for aesthetic reasons.
  #2   IP: 147.147.105.126
Old 19-06-2017, 05:29 PM
Powerfab Powerfab is offline
Default Re: Drainage Channels
If you know the manufacturer of the channel go to their website.
Nearly all provide throughput flow for their channel.
  #3   IP: 82.129.124.11
Old 19-06-2017, 05:38 PM
That's not a huge area so should be more than adequate.
Either way, you are covered as its been designed by someone who's paid to check these things and you are just installing their design.
