  #1   IP: 5.170.120.157
Old 16-12-2018, 08:43 AM
orzoway's Avatar
orzoway orzoway is offline
Question help advice construction rake ripper from excavation
if possible we would like some practical advice to build a digger rake ripper for excavator to clean the ground from roots pebbles bushes to be used as a tool instead of the classic excavator bucket, some user friend has made one using recycled recovery materials from the junkyard or modifying some old classic bucket welding steel teeth? we would need pictures with measurements and materials needed thanks
estimated dimensions to revise: 1 meter wide, 8 teeth of 45 cm long, 15 cm distance between one tooth and the other,, what do you recommend that size material used to build it homemade in economy?
tutti siamo nati matti qualcuno lo rimane
  #2   IP: 31.49.120.24
Old 04-01-2019, 07:18 AM
diggerman's Avatar
diggerman diggerman is offline
Default Re: help advice construction rake ripper from excavation
The second and third pics are a rake I made and my old volvo digger.made rake from amazone power Harrow tines at 100mm spacing and I bit of 4x2box
Nick...
  #3   IP: 5.170.120.121
Old 04-01-2019, 09:55 AM
orzoway's Avatar
Question Re: help advice construction rake ripper from excavation
we need a similar tool to clean up a farm abandoned for some time, buy it new or used costs an impossible figure for us with the bucket work proceeds slowly, so we would like to build one of them by hand recycling pieces of metal that we can recover with mechanical scrap or workshop , perhaps by modifying an old bucket, or by building a rake to be bolted to the bucket instead of the teeth, what advice should you use? thanks for collaboration
:confuso:
  #4   IP: 212.88.42.35
Old 21-01-2019, 01:51 AM
Nick...
fifth pic is shovelhands IIRC
  #5   IP: 5.170.120.208
Old 21-01-2019, 08:33 AM
orzoway's Avatar
which one you're referring to, excuse me, VDruid, you're a user of other excavator forums,? if so, I think I have seen your discussions in other forums, am I wrong?
