  #1   IP: 84.92.35.19
Old 06-01-2019, 04:32 PM
Flagstaffview Flagstaffview is offline
Unhappy Mystery starter
Takeuchi TB125 starts when fresh but not on further attempts that same day.
Have attached bypass wire to touch on live terminal at battery and it then starts but itís a pain to have to get out to do it.
Can anyone explain whatís wrong?
Perplexed Louis
  #2   IP: 212.88.42.35
Old 11-01-2019, 11:35 PM
Default Re: Mystery starter
but'll then start the following day ????? once?
do you isolate the batteries overnight?
have you tried isolating and then re-trying it ?
sounds like a control system fault
do you have any dash lights on once started ??
might possibly even the be the isolator itself??
or a dicky earth to the starter relay
  #3   IP: 151.230.151.118
Old Yesterday, 09:04 AM
Edenboy Edenboy is offline
It could be a hydraulic service pressurising the system. When it's cold the pressure has released overnight. When its warm the pressure has built up again. Try the offset pedal or breaker pedal?
Just a thought.
  #4   IP: 212.88.42.35
Old Yesterday, 01:28 PM
Just a thought.
it's an electrical fault ..... it'll start with a jump wire to the starter
  #5   IP: 86.181.177.186
Old Yesterday, 11:29 PM
grifferr grifferr is offline
Maybe the key switch on its way out.
electrics, starting, takeuchi
