  #1   IP: 95.148.130.24
Old 11-01-2010, 12:17 PM
RolyD8k RolyD8k is offline
Default Caterpillar Dozers and Scrapers
Hi everyone,starting off with a line up of some of the kit in drier
times,and chance to do some servicing,click on pic,to enlarge.
RB
  #2   IP: 86.144.91.125
Old 11-01-2010, 02:16 PM
Guest1 Guest1 is offline
Default Re: Caterpillar Dozers and Scrapers
Nice shots Roly,the drivers will be spoiled with that air con.
  #3   IP: 95.148.130.24
Old 11-01-2010, 03:27 PM
Thanks Sean
The modular cabs are not to bad but in the standard cabs are enough
to cook yer, with the hydraulic tank in the cab with you and heat
coming up from the transmision bugger its hot,they rearly do need the
ac in warmer weather with the hours there doing
RB
  #4   IP: 95.150.137.20
Old 11-01-2010, 05:06 PM
Roly hope you dont mind if i add pictures to this thread
this was working in bracknell a few years ago
the blade on this was offset to one side ,i did have some pictures somewhere
showing the differance
cheers graham
  #5   IP: 95.148.130.24
Old 11-01-2010, 05:39 PM
cheers graham
Please do Graham more the merrier, i remember something
about that blade being offset,but at the minute cant think
whywe still have our old cat 70 box and i keep
threatning to hyd it for one of the D6,s but never get
round to it.
  #6   IP: 95.148.130.24
Old 11-01-2010, 06:57 PM
The very first Cat we bought was a very tired D6c82A in 1968
a base machine worked to death on a 5000 acre estate,after
a seasons ploughing we visited the scrap yards for a blade for
it,consisting of 955 rams,fowler challenger A frame and Allis
blade,here,s a picture of the first job we did with it, dozing
a wood out in middle of December,then knocking down a hotel
before going on hire to Highways on the Eaton Socon By-pass.
RB
  #7   IP: 195.93.21.65
Old 11-01-2010, 07:34 PM
Roly that looks like a blade built for some heavy work.....ideal for tree work !!
  #8   IP: 88.109.39.8
Old 11-01-2010, 09:19 PM
Richard's Avatar
Richard Richard is offline
Roly, what was the turning point going from the D6s to D8s, was it for a specific job or just natural progression?
  #9   IP: 95.148.130.24
Old 12-01-2010, 10:02 AM
Natural progression Richard,bought an onions 9/11yd box for the 82A,sold
the troublesome tractor in 1972 and bought my first and only new cat
a 140hp D6c46j its still being used,to be joined later by a D6c47j that
even pulled a 6 furrow ts69,needing to move more muck two 22A,s came
in late 1970 we still use them,with the pressure of work i bought five
68A,s in the early-mid 1980,s then needing even more output i upgraded
to six D8K,s early-mid 1990,s that we still run today,i once swore i would
never own a hi-drive,but after using one we now run eight of them,
there a pleasure to work on, i,ve found some pictures of the 46j
working in 1973-4 on spittals interchange A14 with RB tylers BTD 20.
last picture the 46j working this year.
RB
  #10   IP: 95.148.130.24
Old 12-01-2010, 02:40 PM
the first time we used a scraper, the onions behind the 82A 1969
RB
