Go Back   The British Construction Equipment Forum > INDUSTRY MATTERS > Industry Chat
  #41   IP: 85.255.237.227
Old 15-02-2018, 08:51 PM
Default Re: Best wet weather gear is....
Anyone got any updates on what the harkie is like or if there are any others that have the tail to stop water running down your back
Need something hi vis for strimming in
  #42   IP: 81.141.206.167
Old 15-02-2018, 10:37 PM
Can't remember when I brought it, but I was still on for Trax from memory so it's over 3yrs ago... but mine is still going strong.
  #43   IP: 85.255.237.227
Old 16-02-2018, 11:38 AM
Cheers ordered one but i think the website i used has broken been bill but cant find my paperwork this should be fun
  #44   IP: 95.147.72.119
Old 16-02-2018, 10:59 PM
Cheggars Cheggars is offline
Originally Posted by grahams View Post
Thought it was the right weather to revive this thread.
What are the current suggestions as to best wet weather jackets and trousers? Preferably hi viz jacket (not worried about the trouser colour) also prefer breathable for obvious reasons.
Kaiawaka are supposed to be very good(And expensive) and available in hi vis apparantly.
  #45   IP: 148.252.129.147
Old 18-02-2018, 06:23 PM
I have a set of non hi vis kaiawaka stormforce 250 quid for the coat was supposed to be the muts nuts and i have never been so disappointed in something the seems all leaked after half hour the sleves are to short the hood is far to small and has a silly stiff bit of plastic stitched in that got bent and is now uncomfortable to wear but its stiched on so cant be removed the rubber bits round your wrists to keep water out are 2 different sizes so one seals tight and one flops around
Its stuffed down the back of the seat for if i forget something better
The swazi waterproof smock in hi viz looks good
I prefer to wear a smock to a coat as i find the zip annoys me on lond coats and short coats the rain runs down your butt crack was undecided between that and the harkie but harkie was cheaper so will wear it with bib and brace
