  #1   IP: 31.50.217.61
Old 10-10-2014, 12:05 AM
grifferr grifferr is offline
Default Some job pictures
Ok this is a reservoir I have to dig. It is about 8m X 4m X 2m deep. I wanted to dig it with some slope on the sides so this and the limited access make it an interesting job. The ground is made up the first few buckets and there was concrete and bricks which I weren't to pleased about. V8 and Minty thought this may be worth a look. It was a washout today!
  #2   IP: 86.165.228.224
Old 10-10-2014, 12:43 AM
Default Re: Some job pictures
Not bad digging lower down though Griff !!
Where was that taken then, 'cos it has persisted down here ALL day an' the wheel barrows are now all overflowin'
Looks pretty dry there?
Tha's gonna be a fair-ish hefalump trap, by the time it's all dug out.
How you shifting the spoil and what're you doin' with it???????
  #3   IP: 92.14.180.172
Old 10-10-2014, 07:20 AM
Are you to put a tank in this excavation ? or will it be allowed to fill with water as it is ? I would be quite sure that if it is left 'as is' the side walls will collapse.
  #4   IP: 176.253.206.241
Old 10-10-2014, 09:50 AM
druid, lets be honest here, in your part of the world the wheelbarrows over flow with rain on a summers day! dont quote me but im sure its been raining in south wales non stop since 1964. ps bang tidy job there griff
  #5   IP: 86.165.228.224
Old 10-10-2014, 11:09 AM
Nah Dan, in '64 it snowed like f*** and buried us and the rest of the country. Must've been '65 you were thinking of!!!!
  #6   IP: 86.26.201.210
Old 10-10-2014, 07:35 PM
strott strott is offline
Lovely tidy excavation there
  #7   IP: 31.50.217.61
Old 10-10-2014, 09:18 PM
Trax it will have underlay and a liner in it so I hope it will be ok. A bit off a problem today I
Found a drain . It was 1.7 deep and quite a bit of flow. It will be a problem for the liner if water is coming behind it and the reservoir is low.
  #8   IP: 81.135.134.187
Old 10-10-2014, 10:18 PM
I presume you're talking land drain here Griff? That's a PITA !!
Could it be utilised as a supply for the irrigation res. or you gonna have to divert it?
  #9   IP: 86.142.155.179
Old 10-10-2014, 10:36 PM
Davejcb Davejcb is offline
Water in the res' or not the liner is still gonna float up if it's getting water behind the liner...
Why does it need to be a open hole like this? What's it actually for? Can't you put soakaway crates in it and backfill over them so it's safe with no chance of collapse?
  #10   IP: 86.152.2.7
Old 10-10-2014, 11:41 PM
Pic 2 if you look a bit closer gra there's a dumper behind the machine. I only just spotted it upon a closer look!
