  #11   IP: 86.128.107.59
Old 14-07-2015, 09:56 AM
Very true. Much cheaper than a tracked loading shovel, with the benefit of a slew.
and a hell of a lot quicker
  #12   IP: 81.147.125.57
Old 15-07-2015, 08:41 PM
Pic of a recent job, putting in the posts for a jetty in a pond, purpose of it is to hang a submersible pump from the end of it. We could have just put a post in the water and hung it from that, but would mean going out in a boat to get to it for servicing and we did another on this site which is very successful so decided a jetty was the best idea.
First posts going in.
  #13   IP: 81.147.125.57
Old 15-07-2015, 08:43 PM
A few more posts, Telehandler mounted knocker coming in to its own here!
  #14   IP: 81.147.125.57
Old 15-07-2015, 08:45 PM
And the finished article
  #15   IP: 2.103.118.130
Old 15-07-2015, 08:49 PM
Bet reaching the levers on the post knocker was a bit interesting the further out you got
What make of screening bucket you are using
  #16   IP: 81.147.125.57
Old 15-07-2015, 09:01 PM
Yea getting to the leavers was eventful! But got the job done without getting the waders on
My own bucket Mog , another bit of homemade kit. But of a story to it, had a job to do with one, was finding it difficult to hire one as my JS only has a one way breaker circuit, looked at buying one, sort of run out of time as the build times were not unreasonable but job was looming, also couldn't quite find what I had in mind, so....I built my own! Went out on the initial job and worked ok, needed a hydraulic mod but other than that has been great for four years now. Really built it for the lime, and it makes a smashing job of it, get the conditions right and will do 450-500t a day easy, but rarely get enough infront of me to go at it for the whole day, but ideal to just go and have a few hours on it as and when I can and the conditions are right.
  #17   IP: 109.156.239.237
Old 16-07-2015, 12:12 AM
some nice work there James and some innovation too
That bucket looks the business - got any more pix of that
Was that completely built from scratch or a modified bucket job
  #18   IP: 109.157.249.69
Old 16-07-2015, 07:53 AM
Yes, step by step instructions of the build would be good. Perhaps an accompanying video as well
  #19   IP: 81.154.237.68
Old 16-07-2015, 08:23 PM
Thanks Gra
I will post up what pics I can, have to say I didn't take as many as I should have, if I did they are not on my phone anyway!
The bucket was a total scratch build, the whole thing was hand cut and welded together, was quite the mission in the time I had allocated to do it!
The concept has been used by others, I am by no means the first, but i didn't copy anything, I don't think there is another one like this, if there is I haven't seen it. It basically uses ten fingered stars out of a Pearson Destoner, others make similar machines but I think Pearson was the first.
It was my first go at one, and there are obviously things I'd do differently now, but wouldn't change it that much for what I'm doing, the only thing we've altered since it was built is the gear sets in the motors, we had no real idea of the speed we needed or the torque so it was a bit of an educated guess, which we didn't get quite right, but it did the initial job and then we changed them and it's not really had anything else since then, done four years on the lime now, so I'm pretty pleased with that. I will get it in the workshop at some stage and make a few mods, but I've been threatening that for the last three years
If I wasn't driving it myself then I wouldn't have made it that big, it is quite a lump, not sure I could have trimmed much weight off it though, without compromising the strength. In fairness it's a bit big for a 22tonner, has to be used with respect, wouldn't let a novice lose with it. Far to easy to bend the shafts from the back.
Also you have to appreciate how it works and not be tempted to cram loads in it, the capacity is there to let the material circulate within the bucket, only if it was very fine material with little debris could you fill it right up, it looks half full when I'm using it but in reality it's probably got more in it than a standard ditcher.
Heres a few pics, like I said didn't take enough, not any early on in the build unfortunately, well not that I can find anyway.
Here's a pic of the chain case as it was being fabbed up.
Having fight with the photos tonight, to big, made it smaller, now wrong way up!
  #20   IP: 81.154.237.68
Old 16-07-2015, 08:59 PM
All the fabbing done, ready for a top coat.
Photo quality seems to have suffered after shrinking
