Go Back   The British Construction Equipment Forum > EXTRAS > Introductions
  #11   IP: 78.147.2.160
Old 05-03-2017, 09:38 PM
Default Re: Reintroduction
Yes it was pumping hydraulic oil into the engine via the timing case. Caused the engine to run away on the oil. To compact the problem the injection pump was on its way out causing the engine to hunt wildly which caused me to nearly shit myself on a road journey one day.
  #12   IP: 86.158.219.0
Old 05-03-2017, 10:19 PM
About time you where back here
  #13   IP: 86.139.38.192
thought you'd put a new pump onto that timing case drive ????
Sounds exciting .... makes a change from machine shitting itself
  #14   IP: 78.147.2.160
Old 05-03-2017, 10:41 PM
Resealed pump but didn't work so still let oil by. I first put the hunting engine down to oil in the bores so as machine gained speed on the road I was expecting it to run away on me again. But cheeks clenching seat foam for a moment, but it went back to normal revs again. I got home in one piece but then I had to replace hydraulic pump and injection pump.
