  #1   IP: 86.149.53.9
Old 18-03-2017, 12:25 AM
Default Up rate towing capacity on a van
Hi All,
as the title asks, does anyone know if you can upgrade the towing capacity on a 3.5 ton panel van?
I remember seeing a link on here for a company doing it to Hilux pick-ups, just wondering if its possible?
Google not throwing much up, only towing laws etc!
Aiden
  #2   IP: 188.223.55.152
Old 18-03-2017, 07:48 AM
Default Re: Up rate towing capacity on a van
Try svtech in leyland, i know they can provide help with vehicle plating alterations.
  #3   IP: 86.7.227.133
Old 18-03-2017, 10:13 AM
Don't think you can on panel vans and if you could would probably need ti be a rwd van. Might be easier/cheaper to change vans to iveco 35c or a pickup
  #4   IP: 82.132.216.226
Old 18-03-2017, 08:26 PM
pettsy pettsy is offline
I updated my crafter from 2t to 2.8t towing capacity with sv tech. What van are you wanting to uprate?
  #5   IP: 90.217.34.77
Old 18-03-2017, 09:26 PM
big jordy big jordy is offline
WhAt is involved in up rating? Is it a physical change to the van e.g. brakes suspension? Or is it purely a paper exercise?
Jordan
  #6   IP: 82.132.216.226
Old 18-03-2017, 10:56 PM
Jordan
On mine i had to send a picture of the chassis plate and confirm the ratio of the diff fitted in the rear axle. They didn't need to inspect van and just sent me a secondary data plate to fix next to the standard one. No parts needed to be changed.
  #7   IP: 90.217.34.77
Old 18-03-2017, 11:05 PM
Ahh ok I see but how does it work? Or how is it legal. And not asking for prices but is it expensive?
Jordan
  #8   IP: 90.217.34.77
Old 18-03-2017, 11:07 PM
Oh and sorry forgot to ask is it changed on the van tax you know the part with all the weights?
  #9   IP: 82.132.216.226
Old 19-03-2017, 01:25 AM
Didn't change anything tax wise as was still a standard commercial vehicle under 3500kg. Not sure about other cases, but the crafter had a designed towing capacity of 2800kg, but for an unknown reason is only rated in the uk to tow 2000kg. There was a way via factory/dealers to make it 2800kg but every dealer I asked had no idea how to do it! Some even told me I would need to run a tacho if uprating Sv tech were very easy to deal with, I don't actually know what they did in the background apart from provide additional plate but I'm sure everything is legit! It's about 5 years ago now when I had it done, was 120.
  #10   IP: 92.14.252.163
Old 08-05-2018, 11:48 PM
Ok so I finally look into to this as I'd like to up the payload of the trailer just a bit.
Sv tech Can re class it to 6.3 ton gross. but it involves a diff change to a lower ratio. To whole thing would cost just over 1000.
I don't think it's worth it for what I want and need.
