Go Back   The British Construction Equipment Forum > INDUSTRY MATTERS > General Business Issues
  #21   IP: 31.49.119.206
Old 13-05-2017, 10:49 PM
Default Re: Payment for sitting on butt?
I've asked before on here- can anyone explain why a cheap, reliable electric lift pump is not standard fitment these days??
mine on the Deutz, in't Drema is a belt driven item on the belt that also drives the water pump ..... no belt = no fuel = no cooked motor
gets my vote
  #22   IP: 86.176.174.62
Old 14-05-2017, 10:39 AM
Nothing wrong with old school cam operated lift pump. Easy to maintain, easy and cheap to change, provided correct replacement is provided.
  #23   IP: 213.205.194.0
Old 14-05-2017, 04:44 PM
I've known many mechanical lift pump problems. I've had no issues whatsoever with 15 electric lift pumps, and they can fit anywhere in the fuel system.
  #24   IP: 31.49.119.206
Old 14-05-2017, 10:35 PM
Absolutely Rob and many a motor's run for years on one .... from cars to trucks, etc. ...... as said now't wrong with the system
I agree with you too Ruben ..... POP to locate anywhere you want and cheap as chips to buy.
pros and cons for all schools of thought .... TBH if mine on't Deutz failed, I'd probably go leccy.......Mr Deutz's'll probably be a pricey item .. but as said, the way that's set up, could be an engine saver
