  #1   IP: 86.130.164.94
Old 29-04-2017, 10:02 PM
Default Another one
Picked up a non running D4D7R as new chains rollers etc , engine is in bits and has been for over 20 years , will be a long term project
  #2   IP: 81.148.229.196
Old 29-04-2017, 10:15 PM
Default Re: Another one
see you used a local haulage contractor Gra ..... lotsasparebits
  #3   IP: 86.130.164.94
Old 30-04-2017, 09:00 AM
blatant disrespect for the law on my behalf
it will be a runner again as and when time permits
  #4   IP: 86.165.39.87
Old 30-04-2017, 09:08 AM
It's a Fendt.... So way more fkn expensive than a lorry.
  #5   IP: 86.130.164.94
Old 30-04-2017, 10:31 AM
Shes a big girl too 920 with 250 hp at the shaft last time it was dynoed , reverse drive too , 11 ton so well capable of handling the hooklift , did not even need to put the roller down to lift the D4 out of its resting place
  #6   IP: 81.148.229.196
Old 30-04-2017, 11:50 AM
the tool for the job BTLs Gra ..... nice to have access to that sort of kit for a job like that ..... would've taken some getting out with a lorry eh
then the lorry'd have taken some getting out the field
  #7   IP: 109.148.62.97
Old 30-04-2017, 01:03 PM
Wow! was going to say, some find but I suspect you've known about it for a long time, just waiting for the "right" time to save / salvage her.
That a bottom roller with suppliers tape still on it?
  #8   IP: 86.130.164.94
Old 30-04-2017, 01:23 PM
yes mate been 8 years or more in the waiting , owner was a bit funny and valued it way over the odds due to the money spent years ago ( he was worth about 90 mill) he passed away and now the family want the site cleared and sold for building , the man who was dealing with it , knew what they were worth , and as i promised it would not be scrapped i got it and yes brand new undercart bar the plates
  #9   IP: 81.148.229.196
Old 30-04-2017, 07:35 PM
Looks like MST to me Rob ..... but could well be wrong
  #10   IP: 86.130.164.94
Old 30-04-2017, 07:50 PM
INMALO when they were at Bordon trading estate
and before the split
