Go Back   The British Construction Equipment Forum > INDUSTRY MATTERS > General Business Issues
  #1   IP: 86.183.42.236
Old 08-07-2017, 12:24 PM
Davejcb Davejcb is offline
Default Building a shed
I'm desperate to build a shed to put all my work gear in and keep it away from home.. I've plenty of farm land but what's the chance of building a random shed in the corner of one of the fields? most of my kit as some point is required for maintaining the land, even tho it's rented out to local farmers and not farmed by myself. Anyone done similar?
  #2   IP: 92.26.211.245
Old 08-07-2017, 02:12 PM
Default Re: Building a shed
Its got to be for ag purposes. I know lots of pretend farmers who have done it.
  #3   IP: 87.113.201.222
Old 08-07-2017, 03:57 PM
modelman093's Avatar
I think that I would be more worried about security than planning ?
  #4   IP: 178.102.11.25
Old 08-07-2017, 05:12 PM
Security wouldn't be too much of an issue, would have it remote monitored and most likely see it from my house anyway. Will search the local planning submissions and see if anything comes up..
  #5   IP: 86.132.144.153
Old 08-07-2017, 06:36 PM
Speak to a GOOD planning advisor, who will know the ins and outs of the area, maybe speak to your farmer friends, who may know a good contact?
I know from bitter experience, that getting this sort of thing done by someone who is not up to scratch, is a complete nightmare! And can lead to costly problems, all because of simple mistakes......
  #6   IP: 31.50.50.4
Old 09-07-2017, 12:06 PM
if security isn't an issue ...... go 'portable' ... no planning required
A friend tried for years to get planning on a shed at his farm ... amongst a load of existing sheds ... and nada
so went out and bought a portable one IIRC 40ft x 120ft .... been up on its slab 20 odd years now and the planners couldn't do a damned thing about it
It's a bloody good shed, much lighter than conventional as it's white HD poly tarp type stuff --- but the dogs balls -- proper stuff -- real thick ... and lets so much light in, it's almost as good as outdoors .... wasn't cheap, but quality costs, has stood the test of time, gave him a virtually instant solution to his machinery storage issues and best of all two very big fingers up to the planners
worth looking into .... they can't stop you putting a slab down to sit one on
  #7   IP: 84.13.240.109
Old 10-07-2017, 09:44 PM
Richard's Avatar
Richard Richard is offline
Try for Permitted Development - 28 Day application. If you are using it to store machinery used to maintain your land then you have a legitimate right to this type of application.
Max. size is 465 sqm, more than 25m from roads, not within 3km of an aerodrome, you can't use it for livestock
It won't go before the Parish Council, just the District Council to approve/deny it.
It might even be worth calling the District Council and asking for a tele-con with a planning officer, just to run through it with them. Be clear about your intentions.
You could ask a Land Agent to make the application for you, usually around 400 notes.
  #8   IP: 86.139.68.135
Old 10-07-2017, 10:21 PM
I was looking for a shed or somewhere to build a shed locally for about 8 years. Finally a place came up but was a bit run down and in need of a lot of work. But had a good sized steel portal framed building and a bit of land with it. I started to get in in some kind of order and erected a perimeter fence and gate and put a decent door onto the building and the next I knew I had the local authority on me for unpermited development and change of use. But I'm a farmer I claimed in the end all they could do was make me apply for retrospective planning for the fence that was within 20m of a public road.
  #9   IP: 31.50.50.4
Old 11-07-2017, 10:49 AM
bloody awful isn't it .... you tidy up what might have been an eyesore and they're on your back like vultures ... WYF is wrong with the system in the UK
  #10   IP: 31.50.50.4
Old 11-07-2017, 11:47 AM
very interesting info Rich .... you sure about the size though .... tha's a hell of a building 5000 sq. ft. .... could park a few implements/traccies in a 100 x 50ft shed
I'd understood it to be 1800 sq. ft. ?? .... hence my target size of 40' x 45' (initially)
