  #1   IP: 5.170.110.163
Old 28-09-2017, 04:16 PM
orzoway's Avatar
orzoway orzoway is offline
Default truck crawler truck camb/ Fresia
thanks, sorry if I ask this question, you know about the chassis trucks bumped for Camb Fresia self - propelled crawler transport, the cambuses had a Fiat Iveco engine, while the freesia I think fiat iveco,. someone uses them or knows nothing about it.
[IMG]https://farm4.static.flickr.com/3846/14837942797_d85db5dd55_b.jpg[/IMG
]https://hiveminer.com/Tags/camb,truck
tutti siamo nati matti qualcuno lo rimane
  #2   IP: 92.28.198.143
Old 29-09-2017, 08:39 AM
Default Re: truck crawler truck camb/ Fresia
The photo at the bottom shows a cab and front bumper which I am familiar with as Iveco. I had a 180 fiat based engine and its fair to say it couldn't pull the skin off a rice pudding. Not for use in hilly country with a 6 speed gearbox at least.
They do fit a Cummins 6cyl to these which is far better and is an easy conversion if you should blow the fiat engine up.
  #3   IP: 86.143.138.182
Old 29-09-2017, 11:39 AM
yep ... quick glance and you'd put money on that being an Iveco Minty
  #4   IP: 5.170.109.136
Old 29-09-2017, 05:03 PM
orzoway's Avatar
Question Re: truck crawler truck camb/ Fresia
the firm fresia is still active produces means for swift intervention, vehicles for the army and the anas the entity that has the management and maintenance roads, tractors for aeroporti, the cambcostruzioni agricultural crafts BICOCCHI of nanantola Modena italia I believe it has closed construiva trucks and I believe the chassis for the crane trucks Ormig motor fiat iveco mercedes 2, 3, 4 ,5 axles for crawler transport and tractors, do you know them these vehicles?
camb truck
