Go Back   The British Construction Equipment Forum > INDUSTRY MATTERS > Industry Chat
  #1   IP: 2.99.169.54
Old 11-02-2018, 09:26 AM
heritage-machining heritage-machining is offline
Default Short term public liability insurance
OK I need some liability insurance to dig a trench across some common land to connect water and electric to my yard I don't normally do this sort of thing so I'm reluctant to get a full year as I only really need a week at the most it's only 50 meters mostly so I can fit it around other stuff also the council want site specific risk assessments and method statements they are not so much of an issue as I can do them as in a past life I did a good bit of that can anyone recommend a suitable company
Thanks Tom
  #2   IP: 78.149.11.121
Old 11-02-2018, 09:33 AM
Default Re: Short term public liability insurance
Get a dial before you dig you may change your mind depending on what you find down there?
  #3   IP: 213.205.242.165
Old 11-02-2018, 09:39 AM
Monkeybusiness Monkeybusiness is offline
Can you not take out a 12 month policy and then cancel it when you are finished? You will pay more than for 1 week pro-rata but Iím pretty sure most insurers will refund what hasnít been used (less their admin fee, and obviously depending on you not claiming in that week!).
  #4   IP: 2.99.169.54
Old 11-02-2018, 09:41 AM
What do you mean a dial not really up on industry terms (mostly I just fix the machines) I do know that there are some electric cables that cross my water trench but handily the electric board excavated them last year to do a repair so I noted where they were I will still hire a catscan tho
  #5   IP: 86.128.247.220
Old 11-02-2018, 09:42 AM
About £250 for a years public liability from Jcb.... Not bank breaking imho
  #6   IP: 2.99.169.54
Old 11-02-2018, 09:43 AM
Monkey business that's a thought they will just charge time on risk will it affect my other insurances tho
  #7   IP: 2.99.169.54
Old 11-02-2018, 09:45 AM
Yes I have had quotes at about that I suppose I could offset it against the business just seems pointless if I'm not using it really unless I get my old kubota out and go and do a bit of groundwork for other people
  #8   IP: 94.192.165.83
Old 11-02-2018, 01:37 PM
if youve got a buisness you should have public liability anyway
  #9   IP: 2.99.169.54
Old 11-02-2018, 05:29 PM
Yes indeed but not for groundworks/construction suppose I could add it on
  #10   IP: 82.10.225.154
Old 11-02-2018, 06:21 PM
If you take out a new policy and cancel it afterwards you may end up with a bump in your normal premium due to having to tell them that you have had a previous policy cancelled.
May just be easier to hire someone in to do it
