  #1   IP: 86.137.0.149
Old 18-02-2018, 05:31 PM
pettsy pettsy is offline
Default Mecalac 8cx on ebay
Came across this on eBay, sadly a non runner.
https://rover.ebay.com/rover/0/0/0?m...2F112785245533
  #2   IP: 185.16.224.33
Old 18-02-2018, 08:16 PM
scoffcruddle scoffcruddle is offline
Default Re: Mecalac 8cx on ebay
What sort of vintage will it be?
I'm one of the watchers,not a lot of use to me though,can't see it being able to float.
You see, in this world there's two kinds of people, my friend: Those with loaded guns and those who dig. You dig.
  #3   IP: 81.151.174.184
Old 19-02-2018, 12:23 AM
showed it to Rory a few weeks ago when it first came on Fleabay .....
He's a bit of a fan ..... and it's relatively/sort of cheap-ish
could be an easy fix or a prize lemon ...... probably the latter
  #4   IP: 86.137.0.149
Old 19-02-2018, 12:45 AM
The first thing that goes through my mind when a dealer sells as spares/repairs is that surely they have a mechanic (or access to one) so if it was an easy fix surely they would fix it?
  #5   IP: 109.145.57.111
Old 19-02-2018, 07:55 AM
S.A.F. S.A.F. is offline
That is exactly how I see it as well, it doesn't give you much confidence buying any of the other listings that they have.
  #6   IP: 81.141.201.57
Old 19-02-2018, 08:38 AM
It's about 2k too much.
Lots of electrics on these to be a problem besides the obvious engine issue.... I like the concept and see them as a much better proposition to a duck for my line of work, but Alas too much money and the wrong end of the country.
  #7   IP: 81.151.174.184
Old 19-02-2018, 11:09 AM
my thoughts exactly when I read it
  #8   IP: 206.45.236.107
Old 19-02-2018, 11:20 PM
800CLC's Avatar
800CLC 800CLC is offline
Isuzu's are generally good engine's could be a plugged up fuel filter, maybe a lift pump. Interesting outriggers on it. Don't necessarily like all the linkages on the back of the boom but would be a great road maintenance machine for ditching, mowing, maybe mulching, and culvert repair.
  #9   IP: 94.12.159.195
Old 19-02-2018, 11:25 PM
lots of dealers will just try turn a profit without touching it once you start digging into it you never know what you will find or how much it will cost
  #10   IP: 81.151.174.184
Old 20-02-2018, 12:41 PM
yeh ... probably took it in, as is and trying to get out of it ahead, without touching it
As Rory says ... 2k too dear, as it stands .... at 3.5k you might chance your arm, after a bloody good look around it .. but at that money you'd buy a whole lot else, fully functional, without needing X,xxx thrown at it
