  #11   IP: 81.151.174.184
Old 20-02-2018, 11:50 AM
Default Re: Mecalac 8cx on ebay
Originally Posted by 800CLC View Post
Isuzu's are generally good engine's could be a plugged up fuel filter, maybe a lift pump. Interesting outriggers on it.
Don't necessarily like all the linkages on the back of the boom but would be a great road maintenance machine for ditching, mowing, maybe mulching, and culvert repair.
'nature of the beast' Bert .... 'swhy they're so 'flexible'
TBF it does look quite clean and tidy for its age
curiously ...... that has a wheel off the deck ????
also looks to have an S type hitch too
  #12   IP: 81.147.100.200
Old 20-02-2018, 03:02 PM
Has it been over?? Hence the knackered engine and wheel off the ground
  #13   IP: 86.137.0.149
Old 20-02-2018, 07:31 PM
pettsy pettsy is offline
Looks like these were possible previous owners? http://www.tonsel.nl Google says nursery?
  #14   IP: 147.147.105.71
Old 20-02-2018, 08:06 PM
Powerfab Powerfab is offline
Is the boom ram resting on the front of the engine cover and putting just enough weight on to twist it slightly on the centre pivot.
And if it's a none runner, how did they get it sitting there in the yard if not under its own steam? It's the last place you'd want a lump of metal blocking all around it.
Perhaps it's got a twist dragging it off the flatbed
  #15   IP: 81.151.174.184
Old 20-02-2018, 11:14 PM
IMHDO .... it's sat on it's hitch, with just enough air to have one boot off the deck.
it's also making engine access damned near impossible ...
can't see it's been over at all ... no visible damage ...
fishy one that .....
WTF park it that way around, with a known requirement to gain access to the motor??
  #16   IP: 81.151.174.184
Old 20-02-2018, 11:17 PM
just noticed ..... it's also missing its knuckle ram .... just a solid link in there
  #17   IP: 147.147.105.71
Old 21-02-2018, 12:44 AM
Don't see any pipes for it. Would a knuckle ram be an optional extra on it?
  #18   IP: 81.141.201.57
Old 21-02-2018, 06:00 AM
Shortest distance for the machine to fit on the lorry.
  #19   IP: 81.151.174.184
Old 21-02-2018, 11:39 AM
good point ..... but why ditch it there
  #20   IP: 81.151.174.184
Old 21-02-2018, 11:41 AM
agree .... link looks like it may have 3 positions, judging by the size of the 'butt end' of it ..... hydraulic adjustment may have been optional
