  #1   IP: 209.93.206.133
Old 23-02-2018, 07:14 PM
Default Excavator core drill
Saw this and thought how good it looked. Excavator mounted core drill run off breaker circuit with self contained water supply.
www.driller.be
I was in Winchester the other day and was pleased to see new bollards had appeared at all the entrances to the pedestrian market to stop jihadists ramming pedestrians. It had been done nice enough, but not perfect. It looked like each hole had a square, disc cut into the pavement then they must have excavated enough to get bollard in then back filled and topped off with tarmac which didnít look that great. This thing would do a much nicer job and I would have thought much quicker and quieter. Mounted on something like a 1CX you could carry all the bollards, resin etc in the front and this on the rear and get through a huge number each day.
File Type: jpg 088AB105-2ED9-43B1-B47B-E3198D216F0F.jpg (12.9 KB, 39 views)
  #2   IP: 81.151.174.184
Old 24-02-2018, 01:17 AM
Default Re: Excavator core drill
www.driller.be
our old friend Mr Seilorman has got a bigger version on his duck Gra
https://youtu.be/vuzEDj4Uas0
  #3   IP: 209.93.206.133
Old 24-02-2018, 10:58 AM
He has everything! His is a home made version, so it does it pretty good job by the looks of it, but it still involves a labourer manually operating it which the Driller one has overcome.
  #4   IP: 81.151.174.184
Old 24-02-2018, 11:27 AM
TBH Gra, having done a bit of D-drilling cores ..... I'd want a pair of hands feeding the drill in .... not a cheap thing to wreck
