  #1   IP: 78.146.180.130
Old 02-03-2018, 11:19 PM
diggerjones's Avatar
Default Digger
Took in Majorca the other week
  #2   IP: 81.147.100.200
Old 03-03-2018, 12:03 AM
Default Re: Digger
That's the one with the pecker built into the dipper.
  #3   IP: 81.129.193.34
Old 03-03-2018, 12:16 AM
Default Re: Digger
wondered WTF it was ... couldn't see how it extended
  #4   IP: 81.147.100.200
Old 03-03-2018, 10:33 AM
Default Re: Digger
I like the idea and would save a lot of ragging of the machine because the driver can't be bothered to put the hammer on. And less chance of shite getting in the hydraulics after labourer has dragged the hammer lines across the deepest muddy puggle on the job
Just curl the bucket out stick point in peck away for a min and then back to digging.
How it effects stability ECT I don't know. I suppose the only down side is you loose some flexability with it been the dipper and not stuck on the end of it.
  #5   IP: 78.146.185.156
Old 03-03-2018, 10:46 AM
Default Re: Digger
I liked the idea, this was a bit knackered. Can you see where the dipper had been welded up
