  #1   IP: 86.176.246.30
Old 14-04-2018, 07:22 PM
Paul38 Paul38 is offline
Default Hiab truck or trailer mounted
I am thinking about a hiab crane which needs to be able to lift 20ft containers.
I run a unit with 35ft low loader, and have a demount body on the unit for small loads
I am wondering firstly what size or crane and second do I mount on truck or trailer, my concern would be no small body after crane is fitted
  #2   IP: 86.139.113.229
Old 14-04-2018, 08:36 PM
Default Re: Hiab truck or trailer mounted
Mogman is the guru for this one boyo ..... drop Paul a PM ..... he's been there, done that ...... and still doing it
  #3   IP: 92.14.71.224
Old 14-04-2018, 09:45 PM
This is my ‘new’ truck with a 10’ body slid on
It’s a 38 tonne meter Crane that will lift 1.5tonnes at full stretch 14.5 meters
But will lift an empty 20’ box to just over 10 meters
I would have the crane on the unit as I find it more flexible
What unit have you got
  #4   IP: 86.176.246.30
Old 14-04-2018, 09:53 PM
hi Mogman, Scania r480, 6x2 midlift
is ten foot body the most you can get on the back after hiab
  #5   IP: 92.14.71.224
Old 14-04-2018, 10:03 PM
No I could of gone to 12’ but I have a draw bar hitch so had to keep the length down as wouldn’t of been able to turn with a screener on
This is the old truck but it has the same hitch
Going to make a 4’ extension that fits onto the body with its own under run bar and lights when I get round to it
  #6   IP: 86.176.246.30
Old 14-04-2018, 10:09 PM
so crane size I am looking at a reach of about 20-25ft, I understand the containers are about 2.5ton, what would the typical size I should be looking for?
Also I assume remote control is the only way to go
thanks
  #7   IP: 86.176.246.30
Old 14-04-2018, 10:16 PM
ill post some hopefully tomorrow.
we used to have a demount beavertail and tipper body, needed to shift heavier plant hence when with a triaxle short low loader. we still have and use the tipper body.
the problem I have some sites I be at are very residential and the small gear only weighs about 4tons.
where the hiab come in is that we have been approached by a customer to shift site container because our low loader would get into places most wont, we shift plant currently for them
  #8   IP: 92.14.71.224
Old 14-04-2018, 10:18 PM
And a 26 footer to shift 20’ boxes and screens, can get in places an 8 wheeler can’t
Can only post one picture at a timeno wonder it’s going down the pan
  #9   IP: 92.14.71.224
Old 14-04-2018, 10:29 PM
thanks
Remote forget it without my first one didn’t have one and it was hard work on your own then the next one had remote it was like going from a black and white tv to colour one
As for size I managed with a 23 ton meter one for years doing boxes but remember the reach is from the centre of the slew, so with a trailer on you have lost nearly 2 meters to reach the other side of the head board then you have to then reach the middle of the box another 3 meters, so 5 meters and you haven’t got any extra
To be fair my 23002 palfinger lifted boxes onto the flat of my step frame but it did have a bit of a tweak between Crane tests but only me used it
  #10   IP: 86.176.246.30
Old 14-04-2018, 10:36 PM
so its that size as a minimum, it will only be used by myself so happy for it to be on the limit
did u fit yourself?
