  #11   IP: 92.14.71.224
Old 14-04-2018, 11:06 PM
Default Re: Hiab truck or trailer mounted
Originally Posted by Paul38 View Post
so its that size as a minimum, it will only be used by myself so happy for it to be on the limit
did u fit yourself?
I fitted the first one that had manual controls was on a Daf 85 made a sub frame that went from behind the cab to the back of the truck and fitted rear legs as well, mine was on air suspension so if it only had legs on the Crane the rear of the truck would be going up and down all the time as the weight shifted when lifting and slewing, it’s a fair job took me a about a week, even made a recess in the fuel tank for the front leg and had to remove the exhaust and make a “new” one that went up the back of the cab out of 4” stainless steel milk pipe on the other side for the leg also.
The other two have had them fitted
I would buy a truck with one fitted but if you think your truck is too good to move on, maybe fit the Crane on the trailer neck would only need the Crane legs because of the length of the trailer plus you will gain 2 meters as mentioned earlier would be a very easy way to fit a crane as will fix straight to the chassis with a few guesses
  #12   IP: 86.139.113.229
Old 15-04-2018, 12:21 AM
I am thinking about a hiab crane which needs to be able to lift 20ft containers.
I run a unit with 35ft low loader, and have a demount body on the unit for small loads
I am wondering firstly what size or crane and second do I mount on truck or trailer, my concern would be no small body after crane is fitted
Told you 'the Mog' is the guru Boyo
And a 26 footer to shift 20’ boxes and screens, can get in places an 8 wheeler can’t
Can only post one picture at a time no wonder it’s going down the pan
Oooh ..... there's me trailer ..... heavily modified
aye well .... what can you say eh ???
  #13   IP: 92.14.71.224
Old 15-04-2018, 09:45 AM
Afraid not, “your” trailer was too low to couple up to my truck this one has 22.5” wheels, I ended up cutting that trailer up just kept the axle for export along with the tool boxes and chock rail which I welded onto this one
My trailer was a urban tautliner so cut the roof off along with the head board and made a nice short flat on air suspension
On a side note should of bought the aluminium rams that your mate had would of been handy on this one
  #14   IP: 86.139.113.229
Old 15-04-2018, 11:08 AM
tha's what that one was too Mog .... curtain sided Tradeteam Excel dray, hence the lil' wheels.
can well imagine it was too low for your 5th wheel though
can't believe that was Nov. '15
Yeh those ramps were a bargain, no question
  #15   IP: 92.14.71.224
Old 23-04-2018, 07:54 PM
This is the rear endow my truck with the drawbar hitch, even got a tow ball for the caravan
  #16   IP: 86.128.106.169
Old 23-04-2018, 11:29 PM
Attachment 29462
Like the air tank strap racks Mog ... I assume the gert ball ended post is for your 5th wheel demountable body ??
  #17   IP: 85.255.236.15
Old 24-04-2018, 10:49 AM
Not quite the strap rack is a couple of gas cylinders welded together and the ball is to shift a Doppstadt basic onto my trailer there is only one in the country at the moment and I’m the only person that can load and unload my self without help
Can’t beat being self sufficient
Would love to show you a picture of it but won’t let
Try later
  #18   IP: 86.128.106.169
Old 24-04-2018, 05:27 PM
Try later:
send it down Mog ... I'll chuck it in here, for you
presumably that Doppstadt post is a drop in jobbie? .... looks smack bang in the way for yer 5th wheel pin alignment
PS ...... love your reg. no. Boyo
  #19   IP: 92.14.71.224
Old 24-04-2018, 05:41 PM
Yes the ‘ball’ fits in a socket welded into the Crane sub frame
So doesn’t interfere with the trailer or the slide on body
  #20   IP: 86.128.106.169
Old 24-04-2018, 05:47 PM
Attachment 29463
Attachment 29464
fairplay to you ..... you love to create plenty of storage on board, for all your gear .... can never have enough, eh ?
Tha's a hell of a hook hanging over the edge of the light unit, storage box
