  #1   IP: 78.146.185.248
Old 11-06-2018, 06:40 PM
diggerjones's Avatar
Default Compact tractor hydraulics
Bought this little tractor recently, have just put a blade on it and am struggling to find any information on where to get a feed from to power the thing.
  #2   IP: 78.146.185.248
Old 11-06-2018, 06:45 PM
Default Re: Compact tractor hydraulics
Front view
  #3   IP: 85.255.235.179
Old 11-06-2018, 06:47 PM
I would say its powered from the rear spools? or does it have another valve which you want to get pressure and return for?
  #4   IP: 78.146.185.248
Old 11-06-2018, 06:58 PM
Hi aiden. Your the man to sort this I know. I just need a feed and return I suppose.
  #5   IP: 81.156.126.80
Old 11-06-2018, 09:36 PM
Basically do this applies to any make tractor https://www.hoyetractor.com/support/...php?article=58
  #6   IP: 78.146.185.248
Old 11-06-2018, 09:42 PM
I know the thing, I used it so the flail didn't drop quick.
There no remote hydraulics on it so need to know where/how to plumb it in. Thanks for the input
  #7   IP: 81.156.126.80
Old 11-06-2018, 09:48 PM
You 2 pipes by looks of it are in the middle right of this pic of yours small one is pressure and other is the supply to tank http://www.ceforum.co.uk/attachment....4&d=1528739830
  #8   IP: 78.146.185.248
Old 11-06-2018, 10:02 PM
How come I'm answering questions that aren't there😕
That link is great . I just have to look for some fitting. Would you think it better to cut metal pipe or get a fitting on somewhere
  #9   IP: 78.146.185.248
Old 11-06-2018, 10:08 PM
Studying the diagram i won't even have to get a return into reservoir. Just one out of feed them one back into feed suply
  #10   IP: 81.156.126.80
Old 12-06-2018, 06:33 AM
as long as its open center valve block
