Go Back   The British Construction Equipment Forum > EXTRAS > Links
  #1   IP: 90.196.146.98
Old 02-01-2010, 10:13 PM
Default Wey and Arun Canal
At weekends I am a volunteer on this canal restoration project.
It has a lot of construction pics and info and I hope might be of intrest to some of you.
We have a Case CX130 exc, a 4.5t Hanix, 6t dumper and 1.5t tracked dumper. Plus a lot of enthusiasm.
Home page. http://www.weyandarun.co.uk/
Restoration projects: http://www.weyandarun.co.uk/rest.php
A compilation I did on a gate repair http://www.youtube.com/watch?v=OEoHyuXfvGE
  #2   IP: 95.150.136.243
Old 02-01-2010, 10:29 PM
Default Re: Wey and Arun Canal
hello rob good to see you here
cheers graham
  #3   IP: 195.93.21.10
Old 02-01-2010, 10:37 PM
Rob we run long reaches in our fleet, would be able to supply some machines for a bit of voluntry on and off.
  #4   IP: 86.168.170.77
Old 02-01-2010, 10:41 PM
incredible to think this used to be a canal!!!!
  #5   IP: 90.196.146.98
Old 02-01-2010, 11:02 PM
That is a very kind offer thank you.
Yep. Those two uprights are all that is remaining of the lock that was once there.
They are the lower gate steels that the gates hinged against. Called coins or coynes I believe.
  #6   IP: 90.196.146.98
Old 02-01-2010, 11:03 PM
Thanks Graham, how long were you going to keep this a secret
  #7   IP: 95.150.136.243
Old 02-01-2010, 11:15 PM
i nearly sent you a link the other night ,but then the phone rang to go gritting and i forgot not long been back in from it tonight
must not complain as it pays some university fees
  #8   IP: 90.196.146.98
Old 02-01-2010, 11:27 PM
Oh christ! not another edumacated digger driver
  #9   IP: 95.150.136.243
Old 04-01-2010, 09:08 PM
no no the offsping seem to be brainy ,enviromental forensics at bournemouth
dont ask for any technical questions on the subject from me
i would like to see more pictures on the canal if you have any
cheers graham
  #10   IP: 195.93.21.34
Old 04-01-2010, 11:11 PM
Graham the brainy kids get it from their parents !!!!
