  #1   IP: 87.113.26.255
Old 31-03-2017, 11:01 AM
Default Jcb 130
Since Hewden went bust we have moved to hiring most stuff from A Plant. They supply JCB 130's nearly new. I couldn't contemplate buying one, it has been driving me mad. Key and code to start, Not just an isolator arm, but a rocker switch as well which is tempermental and don't get me started on the quick hitch - a complete nightmare. No shut off valves in the breaker circuit just above the couplers, so to change a duff one meant oil pouring out everywhere.
Which brings me to my point after that rant. We need to dump the pressure in the breaker circuit before dropping off our rotary sieve. I can't work out how to do this and we ended up with so much pressure locked in the sieve even the coupler tongs wouldn't re attach it. Anyone know the trick?
  #2   IP: 86.169.128.165
Old 31-03-2017, 11:44 AM
Default Re: Jcb 130
to release pressure in my aux circuits I just do the usual.....
shut machine off, turn ignition back on, drop the arm/dead man and operate that circuit a few times .... usually dumps any latent pressure in the lines
TBF .... I don't often need to do it though
Failing that Gra ...... crack a union off
  #3   IP: 185.69.144.235
Old 31-03-2017, 03:01 PM
Default Re: Jcb 130
Check for a switch that makes no sense i think it looks like a spray it may have one it may not with engine running hold for 10seconds
The shovels and telehandlers have this now although some of them have it under the step but think if a digger had one it would be in the cab
  #4   IP: 87.113.26.255
Old 31-03-2017, 04:46 PM
Default Re: Jcb 130
Tried that, but didn't make any difference. Might be because it is a one way circuit.
I had to crack a union in the end, but don't like releasing hydraulic oil on site.
  #5   IP: 86.169.128.165
Old 31-03-2017, 11:58 PM
Default Re: Jcb 130
Probably the motor not allowing any flow from the pressured line Gra ..... could've tried spinning the drum over a little manually, to allow flow from P to the T line, which is, (or should be), direct to tank on the breaker circuit ... no resistance/open line to tank, with only the tank pressure against it (very little) !!
  #6   IP: 31.185.213.2
Old 01-04-2017, 02:13 PM
Default Re: Jcb 130
That is a good thought. I've finished that job, but next time I'll try pulling the drum round manually. Be very handy if that released the pressure.
  #7   IP: 86.169.128.165
Old 01-04-2017, 11:42 PM
Default Re: Jcb 130
certainly worth a try Gra ..... can't be much else holding the pressure that high
  #8   IP: 86.140.132.1
Old 02-04-2017, 12:57 AM
Default Re: Jcb 130
There would be a check valve in the attachment somewhere to stop you rotating the wrong way, this would also stop the pressure releasing. A hydraulic motor wouldn't hold any pressure for long as the are not sealed all the well it's normally just metal to metal. I normally when I shut the machine down turn off the ignition and as the engine slows and pressures drop I continually operate the auxiliary circuit to release the pressure as much as possible before the pilot pressure is gone. Doesn't always work but does help most times
  #9   IP: 86.169.128.165
Old 02-04-2017, 01:17 AM
Default Re: Jcb 130
Gra's screen-er is on a single acting breaker circuit, with no potential for running backwards, so I doubt there is any thing, other than a CLRV, to prevent over pressuring on start up/shut off, of the motor, in its circuits.
I'd agree that the motor shouldn't in theory hold pressure for long .... if it's a gear motor ..... a piston type'd be a different animal though
  #10   IP: 87.113.26.255
Old 02-04-2017, 05:55 PM
Default Re: Jcb 130
You are right, there is a check valve to stop it going the wrong way. Been a pain ever since I bought this one. The four others I have are older models and run both ways. Don't hold pressure either.
If I were to find the check valve and remove it what would be the problem with running the motor backwards - works fine on the older models?
