  #1   IP: 143.159.188.72
Old 26-07-2017, 08:55 PM
Devondumper Devondumper is offline
Default Yanmar VIO25 oil change
Hi, anyone here know where I will find the oil drain plug on a Yanmar VIO25 mini digger?
Thanks.
  #2   IP: 5.65.232.117
Old 26-07-2017, 09:29 PM
Default Re: Yanmar VIO25 oil change
on the sump
  #3   IP: 143.159.188.72
Old 26-07-2017, 09:34 PM
Yes, thank you for that. I know it will be on the sump somewhere but access is extremely limited and before I start taking out the battery or other bits (which I think is necessary on some diggers) I wondered if anyone knew specifics.
  #4   IP: 5.81.144.139
Old 26-07-2017, 09:40 PM
wee_gus's Avatar
wee_gus wee_gus is offline
If you can't find it get a vacuum bucket and put the hose down the dipstick! That's what I do if it's a pin getting to the plug
MacAulay Plant Services - Nationwide Coverage. Servicing, Repairs, Maintenance, Welding & Hydraulis
  #5   IP: 31.52.94.221
Old 26-07-2017, 10:00 PM
Originally Posted by mart1602 View Post
on the sump
PMSL Mart yn ..... very droll
  #6   IP: 31.52.94.221
sounds like a plan that
  #7   IP: 143.159.188.72
Old 26-07-2017, 10:16 PM
Yes, thank you.
  #8   IP: 5.65.232.117
Old 26-07-2017, 11:07 PM
sorry but i just couldnt help my self
  #9   IP: 5.65.232.117
Old 26-07-2017, 11:20 PM
the plug is on the side of the sump directly below the oil filter
  #10   IP: 31.52.94.221
Old 26-07-2017, 11:35 PM
LOL guessed as much .... Devon'll soon get used to the craic
