  #11   IP: 82.132.218.112
Old 04-08-2017, 06:31 AM
Devondumper Devondumper is offline
Default Re: Yanmar vio25 oil warning light/alarm
Sadly I'm on holiday from this weekend and I will be resuming my digger disparity on return from in a couple of weeks, at which point I might take up your offer if you are around at any point. Meanwhile I too wonder whether the oil
spec might be wrong.
  #12   IP: 86.132.145.234
Old 04-08-2017, 07:28 AM
I'd get that bloody synthetic stuff out of it! It's to thin imo, find the correct spec, but a decent quality 15w/40 mineral oil will be just as well.
  #13   IP: 176.12.107.132
Old 04-08-2017, 07:50 AM
I was told when I bought the thing that the engine type is 3TNE68NBV but this brings up nada when I Google it.
  #14   IP: 86.132.145.234
Old 04-08-2017, 10:29 AM
Have a look on the Morris Lubricants website, they have an oil finder, might be worth a look.
  #15   IP: 5.254.163.144
Old 04-08-2017, 11:15 AM
Don't worry about the grade too much. Like Shovelhands says, a decent 15/40 mineral will be fine. Any oil in there should keep the oil pressure sensor happy.
Odds are the sensor has been failing and has now failed, or there is a failure in the sensor wire insulation.
  #16   IP: 81.158.72.72
Old 04-08-2017, 12:05 PM
Id defo be checking the Oil pressure sensor, if you have acess to a pressure gauge id check oil pressure to0!
Aiden
  #17   IP: 81.158.72.72
Old 04-08-2017, 12:15 PM
Aiden
  #18   IP: 109.189.196.27
Old 04-08-2017, 12:41 PM
Bucket on wheels Bucket on wheels is offline
3TNE68NBV drop the last three letters and you get many hits on google
look below
Search results with 3TNE68
https://www.google.no/search?num=100....0.UkLl5NK7cQE
There are basically two types of people.
People who accomplish things, and people who claim to have accomplished things.
The goal is to be in the first group.
Because it is less competition there.
  #19   IP: 176.12.107.132
Old 04-08-2017, 05:52 PM
Yes, you're right, lots of google results. Thank you.
  #20   IP: 81.129.193.101
Old 05-08-2017, 12:58 AM
man after my own heart ..... won't go far wrong with Shell's Rimula-X, as a good general detergent oil. Exceeds most spec.s known to man
Good enough for everything I've run for decades .... and them crane engines did not come cheap
