  #1   IP: 78.141.8.38
Old 07-09-2017, 05:09 PM
peterpecker peterpecker is offline
Default Thwaites 6t dumper cutting out
As per title
Just picked up a s/h thwaites dumper. If it's at standill you can keep the revs up without it cutting out but if you travel over 50yds with the revs up it cuts out. Give it a min and it'll start up and you can do the same.
Any ideas?
Cheers tia
  #2   IP: 80.189.7.152
Old 07-09-2017, 05:43 PM
Powerfab Powerfab is offline
Default Re: Thwaites 6t dumper cutting out
Would have thought fuel starvation the most likely culprit. Check filters and any crud sieve in the base of the tank.
Might also be air getting into the fuel line, although that would usually make it harder to start. Check for any joints in the fuel line or at the pump needing nipped up.
I would think the fuel tank is on a gravity feed to the injector pump, but if there's a fuel pump, mechanical or electrical, it might be playing up.
  #3   IP: 81.132.54.130
Old 07-09-2017, 11:23 PM
It may be worth disconnecting the stop solenoid, the may be a wire shorting out causing it to stop. Or is there a switch in the seat with dodge wiring.
  #4   IP: 78.141.8.199
Old 12-09-2017, 08:28 PM
would it be safe enough for me to take a live straight from the battery and run it like that or would i be risking something else?
  #5   IP: 81.129.192.19
Old 12-09-2017, 08:36 PM
take a live to where ????
  #6   IP: 91.125.138.232
Old 12-09-2017, 09:06 PM
To the seat switch
It will fry his cheeks every time he sits down, and cut out every time he gets up
  #7   IP: 81.129.192.19
Old 12-09-2017, 11:23 PM
Originally Posted by Powerfab View Post
To the seat switch
PMSL ...... don't think there is one on a 6t Thwaites ... or it'd be on / off like a whores draws on rough ground
Certainly ain't one on mine
I assume he means to the stop solenoid
  #8   IP: 78.141.8.199
Old 14-09-2017, 09:08 PM
haha. yes i mean the stop solenoid. Im not into fifty shades stuff
so I went ahead and put the feed straight from the battery and it runs fine...
Except it now uses water more than moses could shift! could the cut out be a safety feature?
  #9   IP: 31.52.88.188
Old 14-09-2017, 09:20 PM
certainly sounds that way Boyo .... any water level sensor in the header tank / top of the rad ???
Where's all the water going ?????
  #10   IP: 5.254.163.144
Old 15-09-2017, 08:57 AM
Why didn't you run the new live from the back of the key switch, so it stops on the key?
Or even better, run a continuity test on the original stop wire which must come off the back of a key.
You need a multimeter.
