  #11   IP:
Old 15-09-2017, 10:20 AM
Default Re: Thwaites 6t dumper cutting out
Why didn't you run the new live from the back of the key switch, so it stops on the key?
Or even better, run a continuity test on the original stop wire which must come off the back of a key.
You need a multimeter.
It sounds as though there isn't a fault at all Doob ..... 'the system' is shutting the dumper down, due to water losses, to save the motor, I'd guess.
