  #1   IP: 213.205.198.52
Old 12-10-2017, 07:57 PM
mattey mattey is offline
Default Jcb 520-4 brake issues
Evening all
I recently went about putting a fell set of brakes in my old 520-4 loadall . I went all out and bought everything and did all the seals whilst at it . I reassembled the axle and filled with a wet brake oil (10-30) . Much to my disappointment it's no better than before really and still makes a loud groaning noise . I've tried a few different oils suitable for oil immersed brakes but still get the same issue .
I was supplied with the brass type brake discs which were the same as what came out . I'm wondering now has anyone fitted the later paper back discs to an early machine ? With success ?
Any thoughts
Matt
  #2   IP: 81.153.45.8
Old 13-10-2017, 08:50 PM
jd 6820's Avatar
jd 6820 jd 6820 is offline
Default Re: Jcb 520-4 brake issues
I would try the oil Manitou supply for their telehandlers, it has a special additive that works very well to cure brake rumble. Iíve not any in stock at the moment so canít give you the spec at this second in time.
  #3   IP: 78.145.200.10
Old 17-10-2017, 09:00 PM
I've tried a few different oils from different manufacturers a . Still the same . Takes near on 40 litres so it's not cheap either
  #4   IP: 86.158.207.57
Old 17-10-2017, 10:09 PM
jd 6820's Avatar
Yeah I agree it’s not a cheap job, fords often had noisy brakes and this was cured using a dose of anti-squawk additive I’m purely suggesting the oil you’ve used hasn’t a high enough content.
