  #1   IP: 89.242.61.189
Old 19-10-2017, 09:17 PM
Richard's Avatar
Richard Richard is offline
Default bushes
Not the green shrubbery, but I am sure I read on here a while back that there's a firm that make/sell oversized bush and pin sets to fit in to freshly machined housings....anyone got any links to them?>
  #2   IP: 5.254.163.144
Old 20-10-2017, 08:44 AM
Default Re: bushes
Any engineering shop should be able to do this for you. It's not oversized if it's the size you specify!
  #3   IP: 148.252.129.246
Old 20-10-2017, 12:56 PM
Default Re: bushes
Hi Richard, we can supply you with these! What size do you need and how many?
  #4   IP: 84.13.243.202
Old 20-10-2017, 07:34 PM
Richard's Avatar
Default Re: bushes
Hi Aiden,
Still in the early stages yet, but would like to sort the dipper nose out on a 655D.....this came about because I have seen someone turn a mag drill in to a line borer and thought "how hard could it be?"
Out of interest do you use some kind of liquid nitrogen to shrink interference-fit parts?
  #5   IP: 5.254.163.144
Old 21-10-2017, 10:05 AM
Default Re: bushes
Hi Aiden,
You just use a hammer or a press.
  #6   IP: 86.138.19.168
Old 21-10-2017, 10:37 AM
Default Re: bushes
Interference fit Doobin is engineered effectively without tolerance, or with a positive tolerance. I.e the Hole Diameter is 50mm and the bush outside diameter is 50.02mm. So under standard conditions they won't fit. You then either heat the outer or freeze the inner, respectively expanding or contracting one part to allow the other to fit with absolutely zero play.
Can buy Liquid nitrogen Via BOC in the tanker, they come out and will generally stay until your done.... think it's 's tho.
  #7   IP: 5.254.163.144
Old 21-10-2017, 12:28 PM
Default Re: bushes
It can still be a press fit. That's why the outer edges are chamfered to allow you to get a start.
For standard digger bushes it won't need to be that tight of an interference fit (as opposed to a gear on a shaft, for instance), so press fitting will overcome the tolerances involved and is standard practice.
  #8   IP: 84.13.243.202
Old 21-10-2017, 07:00 PM
Richard's Avatar
Default Re: bushes
sometimes in farm sales there are A.I Flasks for sale, they run on liguid N. Just have to source the gas.
  #9   IP: 5.254.163.144
Old 21-10-2017, 07:07 PM
Default Re: bushes
This has Darwin Awards written all over it.
Make your bush an interference fit that can be press fitted, and save yourself a lot of hassle.
You could ask to borrow your local mechanics nitrogen flask, but you would find that they don't have one...
  #10   IP: 84.13.243.202
Old 21-10-2017, 10:37 PM
Richard's Avatar
Default Re: bushes
Well thank you for your contributions to this thread. But I will make my own decisions on whats best for me, not what you think. If you have nothing else constructive to add then don't bother.
