Go Back   The British Construction Equipment Forum > EQUIPMENT > Commercial Vehicles
  #21   IP: 86.143.138.182
Old 03-10-2017, 11:27 PM
Default Re: 7.5T Lorries
Originally Posted by V8Druid View Post
with you on that one .... My Iveco was a 21' flat / drop side and dependent on where it was going and what was on it ... it got a 1200kg concrete test weight parked on top of the rear axle, if there was enough to spare to allow it
weighed in at a dead 4050kg empty
and pulled like a train at 11t GTW .... better than empty
Was about to respond to your mate Rory and he appears to have ****ed off along with his post(s) i was about to quote.
he was right about 7.5 tonner's GTW being 12t .. not 11t as I mentioned earlier, but ..... you'd need a dedicated draw bar trailer to go behind the 7.5 and with the extra build weight of that AND the cost, you'd gain now't, which is why I'd said 11t ..... 3.5t Ifor type trailer on a 3.5t max. cap. ball coupling
Think you may have pissed him off
  #22   IP: 86.136.5.222
Old 03-10-2017, 11:46 PM
quattromike quattromike is offline
I thought I was missing something! It wasn't making a whole lotta sense to me.
Dafs are fairly popular so should be able to pick something up with the tipper style your after, don't know about the hiab though you may have to go up a weight class for that to work out.
  #23   IP: 86.143.138.182
Old 03-10-2017, 11:53 PM
Toys out of pram Mike .... wasn't pleading his argument too well
  #24   IP: 85.255.234.80
Old 04-10-2017, 07:17 AM
smiffy smiffy is offline
Originally Posted by JD450A View Post
Smiffy - Yeah, a Urban Artic would be cracking and I regret not picking up Grahams Mates. Only issue is it is then another Trailer to MOT and Another big chunk of money tied up on the operators license. Easier to just run rigid sadly.
What about a tri axle ifor with i hiab on
I have seen some fair size hiabs on them and it would save some payload and mean that if someone with grandfather rights needs a hiab they can take the trailer on the back of a van or pickup
  #25   IP: 86.138.20.91
Old 04-10-2017, 02:56 PM
Just to wrap this up whilst i'm still pissing myself with laughter....
We pay around 2500 a year for the Merc 1317 skip lorry. 7t payload and 3.5t Drawbar. We have two months left to renewal...
Told it will be an additional 100 over the two months to change to a 2006 Daf 7.5t lorry.....
End of, that's killed that!
on the Hiab note. I've got a swing arm crane coming for the trailer when we need it.
