  #1   IP: 185.15.106.82
Old 09-05-2016, 01:34 PM
814_merc 814_merc is offline
Default Looking for a trailer axle central scotland
Hi
After getting good advice on other things I thought I would ask here...
Im looking for an axle for a trailer - something off a 7.5 tonner or a bit bigger.
Ideally double wheel. Does'nt matter if it has brakes or diff, don't need suspension. Its to be welded to a scrap steel boat to transport it along a farm track so not looking for anything too fancy
Central belt/renfrewshire/ayshire ideally
Matt
  #2   IP: 81.174.242.105
Old 10-05-2016, 09:53 AM
oldchips oldchips is offline
Default Re: Looking for a trailer axle central scotland
Withams, mod-sales.com, are always a good place to start for this type of thing, just that south Lincolnshire isn't central Scotland! They do collect MoD stuff from everywhere and do good deals on delivery, worth a phone call.
  #3   IP: 86.113.123.34
Old 10-05-2016, 08:20 PM
You will need a diff as the half shafts will be flapping around and the hub bearings will not support the weight alone
  #4   IP: 2.26.160.122
Old 10-05-2016, 08:44 PM
Just cut the half shafts out leaving the bolt flange cap to keep bearing clean and pack with grease. Or leave diff in..
  #5   IP: 2.28.165.173
Old 10-05-2016, 10:19 PM
davids davids is offline
id try robin campbell near dumbarton
  #6   IP: 86.130.144.70
Old 11-05-2016, 12:23 AM
Wilsons auctions dalry or Morris Leslie at errol . You could possibly try commercial guys like Phillip c smith commercials or other truck breakers .
  #7   IP: 85.255.236.166
Old 13-05-2016, 01:24 AM
Thanks all,found one now. Took a bit of cutting to get it free from a rusty trailer and then some elbow grease to get the drums off from the seized brakes but now it's rolling, all 400kg of it. Next task is to stick it on the bottom of the boat hull. Cheers.
