  #1   IP: 83.205.159.196
Old 15-11-2017, 06:42 PM
Default Hookloaders
Looking at hookloaders in the 12T GVW class to job a little 5.5tonner about - seems to be between the three below which appear to be the most popular (at least over here)
Iveco eurocargo 120E 18
Renault Midlum 190-12
Mercedes Atego 1218
They are a hell of a price over here in france anyone got any experience good or bad with them ? anything I should look out for ? never had anything to do with hookloaders before.
  #2   IP: 92.28.205.242
Old 15-11-2017, 07:47 PM
Default Re: Hookloaders
Would it be worth adding tractor/dump trailer to the list?
If your mileage isn't too big that is. Some of the dump trailers will take a digger of this width I believe. Hookloader/trailer combos are also available.
I would be happy with an iveco if its going to be spending a lot of time parked outside the job. I did find that in the 18t version 180hp coupled with a 6 speed box isn't man enough for hilly country or anything very demanding off the highways. With 12t you would be OK I guess.
Sorry no direct experience with hookloaders. Also I think the more recent Renault trucks share a fair amount of Volvo parts according to my fitter so I would take a look at these.
  #3   IP: 92.28.205.242
Old 15-11-2017, 07:56 PM
Guess I never rated Mercedes as from experience over the years the cabs always rotted out and they weren't well regarded as tippers. I expect all that has changed now though but my opinion has been permanently skewed.
  #4   IP: 86.138.19.78
Old 15-11-2017, 08:26 PM
Won't go wrong with an Atego, As with the older Mercs they are much heavier construction than the respective Iveco/Daf, but IMHO they will last longer.
We have the last Pre Atego 1317 working locally. Lots more about as horse wagons or vintage tractor shifters. 814/817's are still popular enough.
  #5   IP: 83.205.159.196
Old 15-11-2017, 08:30 PM
Like the u.k its a minefield with tractors and trailers - o.k for agri and forestry - we could run one for the forestry related jobs we do but for the bulk of our work it would be winging it.
I wondered whether the 180 would be man enough for the 12 tons - looking at approx 2009 MY which all seem to be about 180 - I notice that some of the newer ones are 220 but then something around 3 or 4 years old is out of my budget - over here they are still looking for about 50K
  #6   IP: 83.205.159.196
Old 15-11-2017, 08:36 PM
yeah I noticed the Mercs weigh more empty ... could be bad or good depending on how you look at it.
  #7   IP: 86.138.19.78
Old 15-11-2017, 08:47 PM
A merc 7.5t lorry chassis is pretty much the same build as the 13t, Just lighter springs and axles.
a Daf or Iveco 7.5t chassis is the same as the 10t variant I believe.
More steel makes it heavier. Depends on your application but if your RAF like me Heavier is better.
  #8   IP: 85.210.151.128
Old 15-11-2017, 11:59 PM
muckyman muckyman is offline
Only ran 6 wheelers but our main problem is bed height so choose a low one.bins are pricey but theres nothing better for moving plant
  #9   IP: 83.205.159.196
Old 16-11-2017, 05:11 AM
noted thanks
  #10   IP: 86.136.9.53
Old 16-11-2017, 10:41 AM
I think Minty meant look at using traccies/dump trailers as a legit method, not as a dodge .....
for limited distance/usage I could see a lot of advantages over a truck, be more flexible and would/could probably be utilised far more on the job too
