  #1   IP: 213.205.194.78
Old 25-02-2015, 04:28 PM
ADTOperator's Avatar
ADTOperator ADTOperator is offline
Default ADT notes
Hi all,
As I've mentioned in another post, I'm off to a CPCS course next week on the ADT.
I was wondering, does anyone have details (pdf or links) on the operation of a CAT725.
After my own searches, I already have the Operation and Maintenance
Manual Excerpt
and the Users Manual.
I can't seem to find anything on the typical safety symbols that could illuminate on the dashboard? Am I missing out on anything else that I can read up on too?
Also any heads up on the CPCS test written, oral and driven?
Thank you for your time.
Always like to be prepared!
ADT Operator
  #2   IP: 213.205.252.220
Old 27-02-2015, 02:50 PM
Default Re: ADT notes
The first step, as they say, is always the ... most fun!
ADT Operator
  #3   IP: 86.144.239.206
Old 28-02-2015, 12:29 PM
Manual Excerpt
Think its safe to say you'll be a few steps ahead of a few on the course if you've managed to find that lot and had a browse, fair play
Have a look at this ( if you haven't already) its the module for renewing ADT catergory.
It will give you an insight into how they understand an ADT is operated on site with some good information if you digest it.
http://cpcsrt.citb.co.uk/FactSheets/...p%20trucks.pdf
  #4   IP: 109.147.28.224
Old 01-03-2015, 12:46 PM
Always good to hear I'm one step ahead of the impeding Drag Curve!
Thank you AtlasRob
ADT Operator
articulated dumper truck, cat725, caterpillar, manual
