  #1   IP: 79.75.72.200
Old 18-09-2017, 06:29 PM
diggerjones's Avatar
Default 180 digger front axle
I'm on a roll now with maintenance, decided to sort the uj on the front axle.
I'm in need of guidance now, I've got the two pins out. Top one easily came out, bottom one took some thrashing. What do I need to do now. I'm struggling to get the steering bits off, not sure I need to though.
V
  #2   IP: 86.135.103.252
Old 18-09-2017, 08:08 PM
Default Re: 180 digger front axle
put some pressure on with the bar you have , then give the housing where the ball joint goes through a swift clout with a good hammer , leave the nut on a bit so you do not fly when it goes
  #3   IP: 79.75.72.200
Old 18-09-2017, 08:18 PM
Cheers graham, I take it you are talking about the steering part. That's good advice will have a go if I need to take that bit off.
It's the main job I'm more concerned with, ie getting it to bits
  #4   IP: 86.155.96.187
You may need to put it back in position a bit so your levering up off a part that will hold the hub down. Also don't be afraid to put plenty WD40 or similar on it and leave to soak a while. Is it a pin holding the steering ram on?
  #5   IP: 79.75.72.200
Old 18-09-2017, 08:53 PM
Thanks, it's the main job I'm more concerned about
  #6   IP: 94.195.250.153
Old 18-09-2017, 08:57 PM
once you get the track rod ends off and steering ram off the hub will come away with the drive shaft then you will have to seperate the uj from the hub and shaft
  #7   IP: 79.75.72.200
Old 18-09-2017, 09:03 PM
It's that bit that I need advice on, separating the hub
  #8   IP: 94.195.250.153
Old 18-09-2017, 09:12 PM
if i remember this right theres a circlip holding the bearing in the uj both sides once you get them out hammer back and forth to loosen the bearings once they come out it should be loose enough to come apart.there will be a short drive shaft in the hub which stays there unless you need to do the seals then you gotta strip the hub ive only done it once under supervision quite a few years ago not on that axle a krammer but should be the same process
  #9   IP: 94.195.250.153
Old 18-09-2017, 09:22 PM
just to add the bearings are a needle cup bearing which go over a pin to hold it tight held in with a circlip .hope thats of some help to you
  #10   IP: 79.75.72.200
Old 18-09-2017, 09:26 PM
I can't see how I could replace the uj with out getting the hub stripped. I could do with someone who could talk me through it step by step. All advice is greatly received so thanks everyone
